No start diagnosis help
Old Aug 18, 2019 | 12:09 AM
huggi's Avatar
Swapped the coils, didn't make a difference. Something about the signal coming into the coil that is awry. I checked the voltage on the two wires (orange and red) they stay at -12.x volts dropping to -11.x when cranking.
The working coil has the same (-12.x dropping to -11.x when cranking) voltage at one of the wires and a varying voltage on the other. It looks like it goes to 0 or maybe +12 volts. Pretty tough to read as it's pretty quick. Either way it looks like the signal into the coil is faulty. What do you recommend as the next step?
Old Aug 18, 2019 | 06:34 AM
ihscouts's Avatar
The coil signal lines are direct from the ECU. I’d say brain box swap just by what you’ve found. If you take that plunge grab the alarm and ECU, they’re supposed to be paired.
Old Aug 18, 2019 | 06:32 PM
huggi's Avatar
Ok I'll pull the ECU see if any connections look funny. Of note, I did find this pin out, which people may find helpful
Old Aug 19, 2019 | 07:24 AM
ihscouts's Avatar
I had nondescript random issues with the ECU, found corrosion on pins. Cleaned them and used dielectric grease and reseated connectors several times and issues never returned. So much for moisture proof..... found corrosion on ECU traces, mostly the boards ground. Cleaned it and revarnished. For an off-road marketed vehicle they sure chintzed on the electrical aspects. Not very well done at all considering the high buy in.
Old Oct 15, 2019 | 03:00 PM
huggi's Avatar
Hello all, good news. New ecu solved the issue. I matched the part number on my ecu with one on eBay. I did not get a matching green alarm ecu thingie.
Old Oct 16, 2019 | 07:36 PM
ihscouts's Avatar
Figured as much. You got lucky without the paired alarm. Glad to hear it's solved.
huggi
Apr 8, 2019 11:05 PM
Austin Busby
Dec 20, 2018 05:12 PM
Kobus van Eeden
Jun 17, 2015 01:20 PM
vsop4me
Oct 8, 2014 10:32 PM
Rover5150
Apr 24, 2008 10:12 PM
