Noticed a slight squeal or noise even with new belt.
Old Nov 14, 2011 | 06:59 PM
Make that the $600 radiator - plus it likes the hood, too. You can drive without the fan as long as you don't stop in traffic for more than a red light. At 45 mph, fan does not have much to do.
Old Nov 14, 2011 | 08:25 PM
primey's Avatar
If fan clutch is locked up constantly fuel economy suffers. Cheap to check, $50 part if need to replace. The clutch "enages" when warmed up to a certain point. But check yor coolant level, want to be sure you are not running too warm (making fan engage - normally it is about 20% power, when hot, 60-70% power), mud clogged radiator fins, trash in between rad and condesner, etc. But fan clutch when stone cold in morning should make a "roar" from being on max as well. So if no fan noise when cold start, might be fan clutch as well.
Savannah you got a link or website where I can pick one up for 50.00 I appreciate your help. I am going to check for the Roar Now. Thanks for the advice..
Primey
Old Nov 14, 2011 | 09:13 PM
see https://landroverforums.com/forum/di...acement-32370/
I did one of these and I think it was about $47 at the parts store. I also tinkered around with some off GM trucks in the junk yard, same size (six inch), and reverse rotation.
Old Nov 14, 2011 | 09:23 PM
Primey
Before you go spending money remove your engine fan and drive for awhile and see if the noise is still there or not.
Old Nov 14, 2011 | 09:29 PM
Spike'e right - complete diagnostics before picking up wrench or wallet.
Old Nov 17, 2011 | 07:48 PM
primey's Avatar
Solved guys, the guy put my belt on wrong, was not in the right order, so got it rerouted thanks to Savannah Posting the link. (Thanks Savannah), the squeal is gone and guess what guys, the Tachometer is working just fine now. Thanks guys you are awesome. I like the Rover better than my new Tacoma..LOL;-)
Primey
Old Nov 17, 2011 | 08:19 PM
The belt link is in the tech section also, and the RAVE, a free copy awaits any optomist willing to stand before a Rover with a wrench.
crumpsc
Dec 22, 2013 08:33 AM
jbarr89
Aug 15, 2011 09:38 AM
Nightmel
Jun 1, 2011 12:25 PM
Nightmel
May 23, 2011 10:21 AM
01disco2
Oct 3, 2009 07:03 AM
