O2 sensors
Old Feb 15, 2011 | 02:46 PM
Chris-bob's Avatar
Default O2 sensors
I pulled this from an earlier post.
Originally Posted by Cosmic88
Location - just forward and aft of each cat on the exhaust down-pipe.
The following is for GEMS EFI 1996 - 1999 (early) and I copied this from a LR tech. bulletin:
The most common sensor used is zirconium based and generates a voltage of between .01 up to 1 volt based on the difference between the oxygen in the exhaust stream and that of the atmosphere.
Land Rover vehicles use a titania based sensor that operates differently. Instead of producing a voltage, the sensor changes resistance in response to oxygen in the exhaust. A rich mixture creates a low resistance in the sensor and vice versa.
A five volt reference signal is supplied to the sensor. In the case of a rich mixture, the low resistance in the sensor "pulls" the voltage low. Conversely, a lean (high oxygen content); mixture will cause the sensor to have high resistance and a high voltage. The typical range on a GEMS equipped vehicle is between less than 1 volt to more than 4 volts.
Is the $50 NGK O2 sensor on amazon http://www.amazon.com/gp/product/B001PNG622/ref=ord_cart_shr?ie=UTF8&m=A139T64LTDCRO8
the correct type of O2 sensor?
Old Feb 15, 2011 | 02:50 PM
Chris-bob's Avatar
Here is what NGK's website says regarding that O2 sensor.
4 WireNon-Flanged OE Identical Titania Oxygen Sensor, Direct Plug In, No Cutting or Splicing Required For Installation. Wire Length: 520mm/20.47in.
NGK also states these are for AELS systems. The non-AELS system O2 sensors are NGK 25017...
So I assume it is correct?
Old Feb 15, 2011 | 06:42 PM
Are you asking which sensors you need to buy?
Old Feb 15, 2011 | 07:49 PM
Chris-bob's Avatar
I guess I was, but then I answered my own question by going to the NGK website. I get to buy cheaper fuel pumps but more expensive O2 sensors...
Old Feb 15, 2011 | 07:56 PM
I guess that a fair trade off.
Old Feb 15, 2011 | 08:00 PM
Cosmic88's Avatar
and there you go...
Old Feb 15, 2011 | 09:07 PM
XCELLER8's Avatar
Cool
Well boys, we shall see about the "amazon " sensors, I ordered 2 of them a couple of days ago, supposedly they were shipped today....I'll report back later , mine are AEL
Old Feb 17, 2011 | 03:30 PM
XCELLER8's Avatar
the sensors were ordered monday and came in today's mail. "NTK" packaging part #25044. The wiring harness is exactly the same as the old sensors ....only about a inch shorter...which wont be a problem. The price was $100.01 for two sensors with shipping. I'll install them, weather permitting ,tomorrow..these should be the real deal though.
Old Feb 17, 2011 | 04:44 PM
antichrist's Avatar
They are the real deal. Land Rover OE sensors are NTK.
I've gotten them both for my '95 and my '97 from Amazon.
ITMagician
Sep 20, 2015 08:47 PM
jsyonker
Sep 4, 2011 06:01 PM
Corsair33
Sep 18, 2006 10:15 PM
riebs
Aug 21, 2006 11:48 AM
JRdisco1
Aug 9, 2005 03:33 PM
