Oil on engine Block
Old Oct 11, 2013 | 08:16 AM
RezzaHD's Avatar
Default Oil on engine Block
I have an oil leak somewhere on my engine for my 1997 Disco. Oil is on the top part of the engine block and i also leak oi when I am parked. Does anyone know what is going on here?
Old Oct 11, 2013 | 08:19 AM
binvanna's Avatar
Best guess is the valve cover gasket. Try tightening the bolts with an 8mm socket. There's tons of threads if you search "valve cover gasket."
Old Oct 11, 2013 | 08:43 AM
RezzaHD's Avatar
Is this the main possibility on why oil would be on the top right side of the engine block? It is almost as if it is slowly leaking over on the right side when I drive it.
Old Oct 11, 2013 | 08:46 AM
WaltNYC's Avatar
Could also be a valley pan gasket... also known as an intake manifold gasket.
Old Oct 11, 2013 | 08:55 AM
binvanna's Avatar
Yes, tighten the bolts, clean all the oil off and see if the leak continues; if it does, then you might need to replace the gaskets. To clean the oil, you can use a can of brake parts cleaner, or if it's bad, a can of Gunk and a power washer.
Old Oct 11, 2013 | 08:57 AM
RezzaHD's Avatar
I will try this and see what happens. I might take pictures to show what I am talking about.
Old Oct 11, 2013 | 02:37 PM
TOM R's Avatar
Clogged pcv causing the valley pan to leak
humroot
Jul 22, 2019 06:33 PM
Rufflyer
Mar 22, 2015 10:13 AM
Noble Six
Jun 4, 2014 04:51 AM
Blakesrover
Feb 21, 2013 01:43 AM
JBEGIN
Jun 27, 2009 12:38 PM
