oil light flicking ,low rpms , dies
Old Jul 8, 2012 | 04:50 PM
Discolife's Avatar
Originally Posted by JumPeR04
here are the codes:1193,1187,1178,1176 and i going do the compress in 30 mins but they havent the oil pressure tester, where can i get one or rent one
http://www.troublecodes.net/landrvr/
P1193
Oxygen Sensor Heater Circuit Open Downstream
P1187
Oxygen Sensor Heater Circuit Short Upstream
P1178
Maximum Positive AMFR Correction Fault
P1176
Maximum Positive FMFR Correction Fault
I am no pro at this but this tell me you have a bad O2 sensor OR you have some dirty electrical connections.
This being said, it pays to clean every connetion you have on your truck. I used WD40 with a tube and dielectric grease.
Old Jul 8, 2012 | 06:19 PM
JumPeR04's Avatar
i got to num 2 cyc and stop since it read the same as number 1
cyc1 1.90 2.110 3.110
cyc2 1.90 2.115 3.115
Old Aug 9, 2012 | 03:37 AM
JumPeR04's Avatar
i finally got the o2 sensors and got them install but three day later Cel came back on, so i went to autozone got it check so now i am down to one code 1187.... thanks again guys....
mikec205
Nov 18, 2014 07:37 AM
Vertigo RT
Aug 20, 2010 06:04 PM
Spencerfitch
May 9, 2010 04:44 PM
lucyyenic
Feb 5, 2010 06:06 AM
free_kid
13
Feb 3, 2010 12:56 PM
