Oil light and overheating. Double threat 1998
Old Jul 9, 2012 | 07:45 PM
  #21
search for "death wobble" as well. Drive shaft U joints?
Old Jul 9, 2012 | 08:07 PM
  #22
Discolife's Avatar
Originally Posted by gulfcoastgorilla
Well the 15x40 rotella oil and the radiator flush fixed both the oil issue and the over heating problem. I'm buying a thermostat tomorrow for it as well. Now I have a third problem. The car shakes semi bad not horribly at 55 mph or so. I checked the tie rods. Everything seems to be sturdy. Has this happened to anyone else. I might just need a tire alignment since I just bought new tires. You guys have been a ton of help. Any input is appreciated
Q's
Does it go away when changing lanes?
Does it stop when braking?
Does it pulse the brake pedal?
How new is suspension, bushings. Is your steering dampner new? Is steering damper weight still attached?
Are your new tires scuffed on any parts of tread?
Old Jul 9, 2012 | 09:04 PM
  #23
gulfcoastgorilla's Avatar
Yes it pulses the breaks and it kid of stops when I go from lane to lane. I will check the others tomorrow
Old Jul 9, 2012 | 09:10 PM
  #24
Bkreutz's Avatar
Loose wheel comes to mind (or loose/bad wheel bearings)
Old Jul 10, 2012 | 02:07 PM
  #25
Discolife's Avatar
Raise the front end grab wheel at 6 and 12 and see how much "give" or how loose it is.
The only other reason you may feel the pulse is a warped disc.....which may cause vibration at those speeds.
Every single car I have ever bought to restore has had worn bearings or needed to be tightened down. Never fails.
geek_IM
Dec 15, 2013 11:27 AM
evomind
Audio/Visual Electronics
Feb 6, 2013 10:01 AM
Savannah Buzz
Feb 6, 2011 05:47 PM
kfx4001442
Jan 24, 2009 05:32 PM
JohnJaquaIII
Aug 15, 2005 12:47 AM
