oil lite
Old Jan 2, 2015 | 06:59 PM
MM3846's Avatar
Toss 1/2 quart of marvel MMO in it first, see what happens.
Old Jan 5, 2015 | 01:12 PM
TOM R's Avatar
Looks like I had 10w/30 rotella t in it, 37* this morning took 18 seconds for oil light to go out
Dad drained and put in some 5w/30 quakerstate so see how that does tommorow
Old Jan 5, 2015 | 01:25 PM
ihscouts's Avatar
We had 4* and my light was on a whole 2 seconds.......truck parked outside.
Old Jan 5, 2015 | 05:15 PM
TOM R's Avatar
Yup I am sure I will need to do the bottom end this year
Old Jan 5, 2015 | 06:58 PM
ihscouts's Avatar
LOL....... Fish, whaaddya doin? There's no way.......
Tom, if you haven't super cleaned up top the bottom aint gonna matter. I already did my shells so I have an unfair advantage but I also cleaned all the baked snot out on the top end. I still have to do a timing chain/gearset this year (if it's still at the house) and I'll be checking the pump specs then as well.
Old Jan 5, 2015 | 07:01 PM
TOM R's Avatar
Gives me an excuse to do 4.6 crank/rods
Old Jan 5, 2015 | 07:32 PM
ihscouts's Avatar
Lol........ yeah, I'm there too but...... what's holding me back is the dang GEMS black box. No matter what you do your still tied to a fat wet map drowning the motor. (Yeah, I said it, picture it!)
Old Jan 5, 2015 | 08:15 PM
TOM R's Avatar
Just throwing this out there and probly not doable but since I did the top end to save me from redoing the top end, what are the chances I can pull the pistons out the bottom and reinstall from the bottom? Trying to figure if I can do this with engine in and top end on
Iirc I had no ridge on the cylinders to reem
Old Jan 5, 2015 | 09:14 PM
It should be doable, if you unbolt the rod caps and pull the crank separately. The hard part will be getting the tranny uncoupled.
Likely a nightmare but doable.
yloDiscoII
ROAMING WITH FRIENDS
27
Aug 21, 2010 07:18 AM
TOM R
Apr 1, 2009 06:16 PM
Deb99DiscoII
Nov 1, 2007 08:21 PM
Kraftyz51
Oct 21, 2007 03:30 AM
jboy
Oct 29, 2006 04:13 PM
