oil pump
Old Jul 20, 2012 | 03:29 AM
jameschristianfuller@hotmail.com's Avatar
3rd Gear
Default oil pump
Hi my name is Christian and i have a 95 discovery and l need to know how do you remove the front engine cover i need to replace my oil pump i just replaced the water pump. Can someone please help thanks.
Old Jul 20, 2012 | 04:16 AM
Sorry, you'll be doing the water pump again. A kit of gaskets and new water pump gears is like $115 from Atlantic British. As for how, that involves having your own copy of the RAVE, the factory shop manual, it is a free download below. While it is open you'll want to evaluate your timing chain for "slop" as well.
In addition to the "fun" of removing the fan clutch, getting the crank nut off is also "fun". Some have made their own special tool, some have used a breaker bar wedged against the pavement or frame and run the starter, some have tangled up the old serpantine belt against things.
BTW, if truck that old replaced water pump, you may want to do fan clutch as well, they usually have been "together" for a long time and the "breakup" and "new best friend" cause tiny off balance vibrations that rapidly wear out the old part.
File Type: pdf
Old Jul 20, 2012 | 08:27 AM
While in there, also replace your very tired timing chain set, if it is original, so you can regain a lot of loss performance.
Old Jul 20, 2012 | 06:09 PM
3rd Gear
thanks for your help.
A5scott
May 18, 2015 06:34 AM
Danobp
Jun 3, 2014 04:15 AM
eaglewing
Apr 16, 2011 11:06 AM
DooDer
Jan 12, 2010 10:46 PM
barranr
Jun 3, 2007 06:36 AM
