Oil pump/timing chain overhaul/ aftermarket gauge instal
Old Oct 1, 2011 | 10:18 PM
Too much trouble, easier to run 10 feet of wire. Just getting to existing oil switch is PITA, a lot of the add-ons use an adapter screwed in between oil filter and the base.
Old Oct 2, 2011 | 10:14 PM
atancreti's Avatar
I will look it up. Can't remember off hand.
Old Oct 2, 2011 | 10:34 PM
EricTyrrell's Avatar
Or you could use an OBD-II USB adapter to a car PC with Streetdeck and a dash mounted display. Now that'd be cool
Old Oct 3, 2011 | 04:44 PM
atancreti's Avatar
Here it is. This is the forum I originally found it from. I also did the temp for oil as well.
Installing Oil and Temp. Gauges - Land Rover Forums : Land Rover and Range Rover Forum
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
anbran
Nov 20, 2011 10:45 AM
DeepBlueWater
Sep 20, 2011 09:21 AM
EstorilM
May 24, 2010 11:03 PM
