oil sender leak
Old Apr 18, 2014 | 09:41 PM
TOM R's Avatar
Default oil sender leak
OK cleaned up the oil running down the filter adapter and let engine run, low and behold coming from oil sender, tightened it cleaned and checked later still leaking so before I buy a sender is there a missing gasket or something? It is leaking between the sender and engine so like from the threads
Old Apr 18, 2014 | 10:00 PM
CUpgt's Avatar
This peaks my interest bc mine leaks there too. Let me know what you find.
Old Apr 18, 2014 | 10:02 PM
ajnolin's Avatar
Yes there is a gasket. Are you sure it's not leaking from the top half of the sender and running along the bottom of the nut? Try some Teflon thread tape. A decent new sender is commonly available for under ten bucks.
Old Apr 19, 2014 | 08:38 AM
TOM R's Avatar
I have seen before where these leak where plastic and metal meet, this is definitely not that, I got a 1/4 + turn out of it like there was supposed to be an boring or gasket now gone? Rover is wierd
Old Apr 19, 2014 | 09:10 AM
jafir's Avatar
O-ring on serpentine belt engines, washer on v-belt engines. If I recall correctly.
Old Apr 19, 2014 | 09:51 AM
TOM R's Avatar
Aha I will try that
Old Apr 19, 2014 | 12:49 PM
TOM R's Avatar
Oil sender bad, new on the way, there is a tiny hole looks like it is supposed to be there, oil leaks from it guess the diaphragm inside is bad
Old Apr 19, 2014 | 04:29 PM
TOM R's Avatar
Grabbed a used one from d2 same leak same spot little hole, ordered a different style for the replacement was like $12 on amazon prime
Old Apr 24, 2014 | 07:34 PM
TOM R's Avatar
Looks like no more oil sender leak, looks like something leaking just above the filter in the front and running down the filter, probly have to remove filter to see it
The oil sender I used is the beck arnley , looks different from original but works fine, it came with a washer I swapped it for a green o ring as mine had a taper on the engine for the o ring
Old Apr 25, 2014 | 02:56 PM
TOM R's Avatar
Oil sender is not leaking, removed filter I cannot see where it is leaking , keep cleaning off with brake clean and comes back after driving all I can see is it comes from above the filter, runs onto filter and drips
The oil line fitting is not leaking
