oil sender leak
Old Apr 25, 2014 | 03:34 PM
OverRover's Avatar
I had this happen on a '96 DI. Check your crankshaft seal.
Even if there is a slight leak the oil will pool behind the lip of the crankshaft pulley. Oil will fling on the front cover, sender, and especially drip down the oil filter.
Just put your finger on the back of the pulley you'll find the oil.
Old Apr 28, 2014 | 03:23 PM
TOM R's Avatar
Found my leak, there is a small disc held in with a snap ring just above the oil filter by the oil line
Anyone know what it is what's behind it? O ring? Would like to know before removing the oil line to access it
Old Apr 28, 2014 | 06:07 PM
jafir's Avatar
Originally Posted by TOM R
Found my leak, there is a small disc held in with a snap ring just above the oil filter by the oil line Anyone know what it is what's behind it? O ring? Would like to know before removing the oil line to access it
If we are talking about the same thing, it's the pressure relief valve. Spring loaded.
Old Apr 28, 2014 | 07:03 PM
TOM R's Avatar
OK what seals it
Old Apr 28, 2014 | 07:58 PM
jafir's Avatar
OK what seals it
I think there is an o-ring on that plug held in by the snap ring. I think. Maybe.
Old Apr 28, 2014 | 09:32 PM
TOM R's Avatar
Guess I need to fix that
Old Apr 28, 2014 | 09:35 PM
jafir's Avatar
Don't misplace the guts. Parts aren't available separately. So I hear.
Old May 6, 2014 | 12:30 PM
TOM R's Avatar
Hoping oil leak fixed! o ring was shrunk and brittle pain to do, changed o rings on the oil line I had to remove since I had it off
This was a bitch to get back in, insert spring, install cap then pushed cap in and wedged a pair of 3/8" ratchet extensions (6" + 3") between cap and frame to force cap in then it stayed by itself while I reinstalled the snap ring
Used green o rings cause I had em
In bottom pic hole on left is pressure relief, hole on right oil line pic is rotated about 90* counter clockwise
Old May 6, 2014 | 05:46 PM
MM3846's Avatar
my truck is leaking from around the same area, i'm gonna be doing the same looking around that you did.
Old Sep 8, 2014 | 09:49 AM
notny41's Avatar
Tom, is your leak gone now? I have similar leak that looks like it is dripping down from the oil filter. I put the dye in the oil to see the source with the blacklight - will be checking it out.
