which one of these champion plugs should i order?!?!?
Yes, just pick a spark plug and go with it. On a stock engine like this you probably will not even be able to tell a difference. Just go with an inexpensive copper plug such as ngk, champion, etc. If you had a built motor running 10psi of boost you would still go with a copper as I did. Platinum plugs have such a small electrode that the spark can be blown out or the tips damaged under high boost.
mx468
12-15-2011 07:52 PM
