which one of these champion plugs should i order?!?!?
Most people probably know it doesn't really matter, that the RN11YC4, or anything equal to them, is fine for a stock D1, so aren't commenting. LOL
These engines are 1960's technology.
Save your overthinking it for something more important.
prior to installing the RN11YC4 's , I was using Bosch Double Platinum, so far I see no difference or reason to go to any of the "high end" stuff out there. I have Magnecore
7mm wires and so far so good.
Yes, just pick a spark plug and go with it. On a stock engine like this you probably will not even be able to tell a difference. Just go with an inexpensive copper plug such as ngk, champion, etc. If you had a built motor running 10psi of boost you would still go with a copper as I did. Platinum plugs have such a small electrode that the spark can be blown out or the tips damaged under high boost.
The only that does not say "platinum" or iridium" on it.
There are only 3 types of spark plugs, cooper, platinum and iridium.
And the prices will reflect as such too...
mx468
Dec 15, 2011 07:52 PM
