Other 95 D1 - Loud ugly transmission noise
Old 01-16-2011, 07:46 PM
mattrickman's Avatar
Default Other 95 D1 - Loud ugly transmission noise
Hello,
So my other 95 D1 (not the one stuck in park). Is making this awful tranny noise when in gear. In fact it will not go in reverse at all... It will drive forward, but something is definitely wrong...
My wife started it up one day and the problem was there, we hadn't noticed anything leading up to this.
What should I do/Check first.
thanks
Old 01-16-2011, 09:39 PM
kenk's Avatar
At the least, I would drain the fluid, replace with new and add a bottle of lucas. But I would strongly suggest dropping the pan and checking the inside of the pan and put on a new filter.
Old 01-16-2011, 11:09 PM
Is dropping the pan and installing the new filter very difficult?
Old 01-17-2011, 07:51 AM
I was going to ask how mechanical you are but your last post answered that.
How do you know it is the tranny, when does it happen?
Old 01-17-2011, 09:47 AM
kenk's Avatar
Changing the filter means dropping the exhaust y-pipe and the crossmember. It's not hard, but many run into broken studs on the exhaust manifold and broke bolts for the crossmember.
Old 01-17-2011, 01:54 PM
1. Remove wife from driver's seat.
2. Do not allow that condition to repeat as it is often the cause of extensive new problems.
eandrews2
05-11-2013 03:57 PM
fideladio
10-15-2010 06:27 PM
AK Rover
ROAMING WITH FRIENDS
07-14-2010 08:52 AM
Street Wolf
Sights N Sounds
11-28-2008 09:22 PM
cek
10-29-2007 09:33 PM
Quick Reply: Other 95 D1 - Loud ugly transmission noise
