Other 95 D1 - Loud ugly transmission noise
Old Jan 16, 2011 | 07:46 PM
mattrickman's Avatar
Default Other 95 D1 - Loud ugly transmission noise
Hello,
So my other 95 D1 (not the one stuck in park). Is making this awful tranny noise when in gear. In fact it will not go in reverse at all... It will drive forward, but something is definitely wrong...
My wife started it up one day and the problem was there, we hadn't noticed anything leading up to this.
What should I do/Check first.
thanks
Old Jan 16, 2011 | 09:39 PM
kenk's Avatar
At the least, I would drain the fluid, replace with new and add a bottle of lucas. But I would strongly suggest dropping the pan and checking the inside of the pan and put on a new filter.
Old Jan 16, 2011 | 11:09 PM
Is dropping the pan and installing the new filter very difficult?
Old Jan 17, 2011 | 07:51 AM
I was going to ask how mechanical you are but your last post answered that.
How do you know it is the tranny, when does it happen?
Old Jan 17, 2011 | 09:47 AM
kenk's Avatar
Changing the filter means dropping the exhaust y-pipe and the crossmember. It's not hard, but many run into broken studs on the exhaust manifold and broke bolts for the crossmember.
Old Jan 17, 2011 | 01:54 PM
Danny Lee 97 Disco's Avatar
1. Remove wife from driver's seat.
2. Do not allow that condition to repeat as it is often the cause of extensive new problems.
eandrews2
May 11, 2013 03:57 PM
fideladio
Oct 15, 2010 06:27 PM
AK Rover
ROAMING WITH FRIENDS
Jul 14, 2010 08:52 AM
Street Wolf
Sights N Sounds
Nov 28, 2008 09:22 PM
cek
Oct 29, 2007 09:33 PM
