Overheating
Old Jan 5, 2012 | 10:40 AM
  #21
Well, it may be academic, as pump volume will also change by thermostat opening size, a stat does not have "snap" action. See pix of thermostat soup and notices variations in opening percentages. Many guys test a new stat on the stove before installing it, just to be sure.
You can diagnose a radiator by temperature usually. If clogged, the lower part tends to be much cooler than the top, because rows of tubes are full of gunk. My indy shop says a good condition radiator, warmed up, would be within 10 degrees F across the surfaces (not the tanks).
Attached Thumbnails Overheating-p1120341.jpg   Overheating-p1120351.jpg   Overheating-p1120359.jpg
Old Jan 5, 2012 | 07:16 PM
  #22
yoshibond's Avatar
Good point - do you remove the fan for this? How do you avoid loosing fingers? Or use an IR thermometer?
Old Jan 5, 2012 | 08:08 PM
  #23
Please, no finger snacks (lol). You do this after truck is warmed up, and you turn off the engine. Feeling by hand (Mark 1 Palm Reader) or using an IR thermometer you check the surface of the radiator in spots "in front" of the fan.
Old Jan 5, 2012 | 09:23 PM
  #24
yoshibond's Avatar
I must be tired .... I guess radiators don't get cold in seconds so I can turn the truck off
Old Jan 6, 2012 | 07:40 PM
  #25
reboot's Avatar
Just for curiousity, anyone have a diagram of the WRONG way to put on the belt? I was looking at my Disco trying to visualize it another way but could not.
Old Jan 6, 2012 | 07:47 PM
  #26
I did not keep it, but my PO had done up my D1 with the belt running across the top of all the upper pulleys, no "under-over". He had also wired the two electric radiator fans to run backwards (reverse polarity), had a fan clutch that had no fluid. When you tuned on the AC at idle, the radiator fan would almost come to a stop because electric fans were subtracting air flow. Of course the radiator was full of calcium.
I guess you could call that condition "POOP" - Previous Owner Originated Problem.
Mike, Spike, and jafir put me on the right path.
IMHO it might be a good idea to print out the correct way, and tape it under the hood with clear plastic shipping tape, just in case a mechanic or DIY check was needed.
Old Jan 6, 2012 | 09:13 PM
  #27
yoshibond's Avatar
I'm still hoping my experience mirrors yours in that all the repairs are those that are fairly inexpensive (haven't really had a chance to do much since I posted here but getting started tomorrow) ...
Based on the price I paid for the truck, I don't mind if I need to replace fan clutch, water pump, get a rad flush, new thermostat, new rad hoses, new head gaskets and maching to straighten out any minor "warps" in the heads ... All I am worried about is a cracked block or cracked cylinder heats from an unknown amount of overheating by the PO.
If I get engine pulled and disassembled tomorrow I should hopefully have a better idea of what I am in for.
Speaking of which - comparing to a 1960/70s Chevy, is there anything I really need to be aware of when doing my engine pull? I plan to pull it out with tranny attached and therefore if it makes sense will just disconnect the driveshaft in front of the transfer case? From there, I am hoping it is just an adult lego project....
Old Jan 23, 2012 | 08:41 PM
  #28
yoshibond's Avatar
As an update on this thread -
Got my rad out and to a rad shop ... they said it was 75% blocked. Great news!
Now - I am deciding to either recore (quoted at $400 or so) or buy a new rad. I have found ones that do not appear to be OEM for about $550 and OEM for about $900 so am leaning towards a re-core.
Once I get that in, I will see if that fixes the problem or if there is engine damage from overheating which will still cause problems....
I am hoping to get it running before I pull the engine for an overhall as this will at least let me know that things are going well.
Wish me luck ....
Old Jan 23, 2012 | 09:42 PM
  #29
Sometimes a used radiator can be found at salvage yard, some from a Range Rover can fit with very little modification. Or go with a basic radiator that will fit (el cheapo supremo) and add a better temp gauage than stock. Two popsicles ought to do better than what you have. Also, rad shop prices vary, try to find a small shop that works on construction and farm equipment.
Some rad prices:
Radiator for Land Rover Discovery 1 V8 - ESR3687, ESR3688 - 1997
or
Radiator Discovery 1 & 95 Classic | Land Rover Engine Parts at RoverParts.com
and Discount Car Parts Stuff - Car Accessories & Truck Accessories - Cheap Auto Parts - Car Cover - Floor Mats - Cargo Liner - 1997 Land Rover Discovery Radiator Stock Replacement
Old Jan 23, 2012 | 10:54 PM
  #30
hh65flyer's Avatar
The Rad shop couldn't rod-out your existing core? That's a much cheaper option if available. Paid less than a $100 for the job...
