p1179 woes
Old Feb 8, 2017 | 04:45 PM
pidge's Avatar
Default p1179 woes
I threw p1179 last week on a 1997 D1.
WHAT I HAVE DONE: Ran Lucas through it.
I replaced the fuel pump -- really this was just wishful thinking based on ONE POST, and didn't help.
I replaced the MAF because ha ha! While I was checking and cleaning the MAF, a piece broke off the bottom; it may have been cracked there. Replacing didn't help. (DID confuse my indie, because while bad MAF was back on truck, it misfired. Now every time I try to discuss with him, he says, "well, it was misfiring..." and I have to remind him of the MAF break-and-fix, and he gets super confused. This conversation will go in circles as long as I allow it so he's little help right now.)
Replaced fuel filter, because it needed it.
Replaced air filter with K&N.
I am waiting for an ipad-compatible code reader to arrive. My old Droid code reader wasn't working, which cost a couple days while I powered up ALL my old Droid devices and tried to get it working. Used someone else's Droid, finally, and the device wouldn't mount.
p1179 came on, hasn't gone away. I have the following qs:
- It's showing a p1179. Would it clear the CEL if I had fixed the issue, or must that code be manually cleared?
- Would the mix run less lean if I had fixed the issue, or would it stay a lean mix until I cleared the code?
- Is the mechanical condition determining the mix with a code displaying, or is the ECU determining the mix?
(I hope you understand this Q )
- Would misfiring cylinder while the MAF was offline dump gas into the oil? I feel as though I smell a little gas in the oil. Obvs I am thinking fuel injector. None visibly leaking. But does gas in oil ALWAYS mean fuel injector, or does a bit of gas get dumped when cylinders misfire? (as they did when MAF plug was pulled while figuring out I'd broken the MAF and then not again)
- WTH.
AFTER all of the above fixes:
It turned over cold this morning after providing fuel pressure by key cycling twice. It then died, as it has been, when it began idle. White smoke. Got it running and warm, power feels fine, idles at 750 evenly, goes above 3000 rpms when goosed, didn't stall. Idles pretty beautifully and feels like it's running fine, but consistently hard starting since the MAF screw up. I feel like fuel hesitates a little from the pedal.
Does any of this rule OUT anything or IN anything?
Suspected culprits:
1. I've already fixed it but need to clear codes for it to take effect.
2. Fuel injector
3. 02 sensor
4. CPS
5. Plugs and wires
6. IAC (cannot for the life of me find to clean).
Remember, I am a dumb girl. I spent a lot of this week covered in fuel and tears. And carbon.
Old Feb 9, 2017 | 06:35 AM
hrhoward's Avatar
Checked all vacuum lines?
Old Feb 9, 2017 | 06:51 AM
jastutte's Avatar
you will need to clear the CEL. It will not reset.
And if the K&N is oiled, replace it with a dry filter. Any brand.
You may want to clean the MAF with MAF cleaner but ONLY when the truck and MAF are cold.
Old Feb 9, 2017 | 09:27 AM
hrhoward's Avatar
Might want to invest in an Ultragauge. Mighty handy. I picked up an EM Plus.
UltraGauge OBDII Scan tool & Information Center
Old Feb 9, 2017 | 12:14 PM
pidge's Avatar
I already have this dude on the way... LELink Bluetooth Low Energy BLE OBD-II OBD2 Car Diagnostic Tool For iPhone/iPod/iPad
Old Feb 9, 2017 | 12:17 PM
pidge's Avatar
whoops, it's not K&N, it's STP.
You know, I am not messing with the MAF right now. Having checked it, broken it and replaced it, I think it's best to leave it alone. It's literally days old at this point, so I don't think I need to clean it.
Old Feb 11, 2017 | 09:20 AM
pidge's Avatar
I seem to be all good now.
My fuel filter was fiiiiiilthy.
That LEL link is wonderful. Really love it. Cleared the codes and the settings they were mandating, and all is fine. No gas in the oil, must have been my smelly gas hands.
Old Feb 11, 2017 | 10:02 AM
jastutte's Avatar
good to hear.
Spencerfitch
Feb 6, 2011 01:07 PM
RoverRover1
Apr 26, 2009 10:48 AM
willlane
Jul 13, 2008 10:28 PM
rcendo
Jan 30, 2008 06:56 PM
Craig
Jul 6, 2007 05:00 PM
