Paul Grant--ABS hydraulic unit
Old Feb 17, 2015 | 10:08 PM
thegoat1's Avatar
Default Paul Grant--ABS hydraulic unit
Hey guys, my abs hydraulic unit has a problem. I'm trying to get some options other than buying a new one, went on eBay and saw a bunch for reasonable prices, however I don't know those sellers=not trust. I've bought parts off of Paul before (with great success)so I wanted o check with him before doing anything to the car. Anywho, I did a member search and I guess I'm not senior enough to get that access and couldn't find a post by him to PM him off of. Does anyone have some contact info or if Paul sees this can you please email me here. I also see there is a repair kit, which my mechanic is going to talk to the British Atlantic to see if that might work for my problem, maybe, maybe not. Either way I'd like to have a back up plan if that's not the solution. Thanks in advance.
Old Feb 17, 2015 | 10:21 PM
dusty1's Avatar
here go
https://landroverforums.com/forum/pr...leather-70454/
Old Feb 17, 2015 | 10:22 PM
thegoat1's Avatar
much appreciated!
Old Feb 18, 2015 | 10:14 AM
Paul Grant's Avatar
Hi Brian,
I responded to your message on eBay and your PM here. I don't have a modulator (I'm assuming that's the hydraulic unit you're looking for) for your '03. As I mentioned in my other responses, make sure whomever it is that you purchase the part from has the means to adequately test the part before they pull and sell it to you. Also, if someone claims to have recently replaced the shuttle valve switch ask if they also replaced the seals. It they didn't you're likely to be revisiting the repair in short order.
Cheers,
Paul
Old Feb 18, 2015 | 02:48 PM
abran's Avatar
Amen.
I laugh when I see sellers selling a used D2 modulator. Unless you they have replaced the seals and the shuttle valve and bi-passed the wires based on fix B, you are going to be installing a faulty unit. If not immediately, in the near future your three friends will appear. I have a box of modulators that I consider junk until I rebuild them properly.
Old Feb 19, 2015 | 10:16 PM
thegoat1's Avatar
yep, that's why I only buy used parts from Paul, he will not steer us wrong. Thanks again Paul, thought I emailed you back on eBay.
Old Feb 19, 2015 | 10:27 PM
CUpgt's Avatar
I have two modulators from D1s that worked when pulled from the trucks.
Baylink
Off Topic
22
Oct 25, 2018 07:55 PM
floundering
May 13, 2014 08:15 PM
JPSpen
Jan 22, 2013 08:45 PM
