Please Help, Replaced Rear Rotors on my Discovery 1 and now it can't go out of park
Old Feb 20, 2014 | 04:22 AM
antichrist's Avatar
First, yours didn't come from changing the brakes, completely coincidental.
Just go with the typical diagnosis, or download the RAVE manuals, read how the system works and trace the wiring.
Old Feb 21, 2014 | 03:18 PM
whywontthiswork's Avatar
8th Gear
Alright, so about 4-6 hours later I made it to the solenoid and removed it. Problem solved, my truck works just fine again with the solenoid removed, thank all of you for all the support you gave, have a great day.
Old Feb 21, 2014 | 05:51 PM
fishEH's Avatar
Don't forget to be careful. There's nothing stopping you now from throwing it straight from D to R while moving.
Old Oct 11, 2022 | 03:50 PM
LovemyRover81's Avatar
3rd Gear
Default Same issue every time I change brakes..
Hi there- I know this is a little late from when you posted but I have had the same issue each time I’ve changed my brakes.. first was 2 years ago I did my front and ended up stuck in park for over a month- one day it just fixed itself… now I changed the rear about a month ago and same deal- stuck in park. I go through the usual process, code read, brake light switch, changed some fuses, looked over all electrical, even removed and replaced brakes and rotors. Still no answer. All fluids are full. I can use the emergency lever under the shifter to get in reverse and in a gear- not sure which it is, but it gets me going only in 1 gear tho…. Curious if you had any thoughts?
Old Oct 12, 2022 | 01:02 PM
czerta's Avatar
Can you depress the button on your shifter?
If no:
Take your shifter head apart and ensure the gear lock functionality works and there isnt any trash jammed along the gear lock shaft. Lube the gear lock shaft as well if its stiff.
Old Oct 13, 2022 | 02:23 PM
fishEH's Avatar
Jump the third brake light and rear defroster connections on the back door glass. Press the rear defroster switch and shift out of park.
Old Oct 14, 2022 | 10:22 AM
WaltNYC's Avatar
Hey Brett. good to see you around here. I forgot about that old trick!
Old Oct 14, 2022 | 10:41 PM
fishEH's Avatar
Yeah it’s been a minute! Almost done with my degree and then I’ll have some free time to rebuild my ‘94 D1. Summer can’t come soon enough!
PiperC
Jan 13, 2012 02:17 PM
RobK
May 24, 2011 08:41 PM
herblatham
Jan 18, 2010 08:49 AM
clockmaker21
Jan 7, 2010 09:20 AM
illuminum
Oct 8, 2007 05:34 PM
