Plug Fouling 96 D1. All plugs.
Old Dec 12, 2010 | 05:24 PM
  #21
thehun's Avatar
I just bought these for 34 bucks Ford Motorsport 19lb/hr...cleaned and tested :0. My landy is already butta smooth at idle, upgrading to these 4 hole injectors will be nice...atomizing the fuel even better..maybe gain a couple of mpg.
Now just FYI, my when I had my 4.6, i do remember the injectors making a more clicking sound than others
http://cgi.ebay.com/ebaymotors/ws/eB...4#ht_500wt_698
just search ford injectors on ebay
Old Dec 12, 2010 | 07:59 PM
  #22
tweakrover's Avatar
not to get off subject, but the ps pump sound in the vid you said was after you filled it with ps fluid, you are aware d1s use atf in the ps pump. didn't know if you just mispoke or was unaware.
Old Dec 12, 2010 | 08:14 PM
  #23
ngarover's Avatar
Good price, but are they the correct injector? I'm seeing C302 injectors, or part FMS-M-9593-C302 being used... these say they are 0 280 155 700?
As to the power steering...
When the guys at the shop finished with the mufflers, he noticed a leaky PS line... tighten it up and topped it off with PS fluid... I'm calling them tomorrow to see if they are going to cover the repair...
Old Dec 12, 2010 | 09:26 PM
  #24
thehun's Avatar
C302 are I think for obd1 systems. 3.9 liters
Old Dec 12, 2010 | 10:02 PM
  #25
ngarover's Avatar
Interesting, cheap enough to give a shot I guess. The listing says they are used injectors. I wonder what testing has been done to them to insure they are good. I bought one of the sets also. For 30 bucks can't really go wrong. If they don't work out I can always resell them. Doesn't look like they come with the o rings etc... I'm asking the seller just to make sure I have everything I need to install them.
Old Dec 12, 2010 | 10:16 PM
  #26
ngarover's Avatar
mine comes with o-rings
Did you ask? The listing only says they have been tested and cleaned. nothing about the o rings.
  #27
thehun's Avatar
Old Dec 12, 2010 | 10:33 PM
  #28
ngarover's Avatar
yup, seller said it comes with the o rings. Used, but should be fine to reuse.
Old Dec 12, 2010 | 11:06 PM
  #29
thehun's Avatar
The ones I got are gen3 injectors..the best atomization injector design...both are direct fit..except mine does not use the retaining clip, but that is easily solved by adding a second o ring on the top-bottom notch of the injector
This got me thinking...since our injectors are junk and its literally just sprays in a straight line with little atomization, this might be why we also see lots of fuel contamination in our oils and massive carbon build ups...hmmm...hmmmm.
Old Dec 12, 2010 | 11:48 PM
  #30
thehun's Avatar
this tells all the differences (we got lucas as oem) check out the atomization differences
http://www.youtube.com/watch?v=Emnax2J4FX4
