Power steering fluid
Old Feb 22, 2021 | 10:38 PM
dmenchaca1966's Avatar
Default Power steering fluid
My 97 disco has a power steering fluid Leakage I’ll figure out where it’s leaking but I can’t remember what’s the best fluid to get.
PS- How’s about on were the fluids might be leaking just to point me on the right path.
Thanks
Old Feb 22, 2021 | 11:10 PM
Best4x4's Avatar
Dex III for a D1
Old Feb 23, 2021 | 06:49 AM
Toran's Avatar
Red power steering fluid + Lucas Transmission Fix (red and very thick).
This is from the DI maintenance section
Old Feb 23, 2021 | 01:35 PM
WaltNYC's Avatar
Valvoline hi mileage ATF is what I use. Note that the steering system uses automatic transmission fluid.
Generally they leak from the seals around the drop arm. Some have had success replacing seals. Most swap out the box for a re-man or a known to be good used box.
Old Feb 23, 2021 | 05:13 PM
Best4x4's Avatar
The Lucas PS Stop Leak has worked for me on RRC/D1 PS systems over the years. Check the hose clamps at the reservoir for being loose, and if those are good it's either leaking from a line, the pump, or the box.
Sailor012
Sep 12, 2019 03:15 PM
Athana
May 29, 2019 07:49 PM
film842
May 7, 2015 02:22 AM
Normd996
Mar 25, 2013 07:58 PM
mc_eyes
Dec 10, 2008 10:52 AM
