Power steering fluid explosion
Old 07-23-2012 | 07:44 PM
I agree with all of the above, the fluid is overheating for whatever reason and as we all know when a fluid overheats it cant do it job.
Then it expands to much and spews out the weep hole.
Old 07-23-2012 | 09:59 PM
XCELLER8's Avatar
Eric...are you running exhaust headers ??? just curious if so, if they could be radiating enough extra heat to cause some problems.
Old 07-23-2012 | 10:05 PM
EricTyrrell's Avatar
Ceramic coated manifolds actually. They radiate a lot less heat so steering temps should be even better than stock. I tried adding thermal insulation to the lines just in case, but it made no difference.
I've sourced a new steering box from Will for a great price.
Old 07-23-2012 | 10:58 PM
Jake1996D1's Avatar
Mind sharing what you paid for it?
Old 07-23-2012 | 11:42 PM
$300 shipped. More without a core (he happens to need one). Great deal either way.
Old 07-24-2012 | 09:49 PM
Banzai Jimmy's Avatar
I run ATF in my S10 pump FWIW. Haven't had any abnormal noise as a result in the couple of years I've had it.
I also added a cooler to my p/s system for a little extra insurance. Added a second factory trans cooler to the front behind the grill and plumbed it between the box and reservoir.
I hope the new steering gear box fixes it for you. I'm just having a tough time picturing it as the problem.
Old 07-24-2012 | 09:54 PM
Danny Lee 97 Disco's Avatar
That is going be one totally restored discovery.
Did you resolve the code issue you were fighting?
sorbet35
04-23-2015 05:27 PM
kmyer01
06-18-2012 06:36 PM
BADFISH
08-26-2009 10:02 AM
jycsalas
04-17-2009 02:21 AM
98roverguy
09-10-2006 09:19 PM
Quick Reply: Power steering fluid explosion
