Power steering fluid explosion
I agree with all of the above, the fluid is overheating for whatever reason and as we all know when a fluid overheats it cant do it job.
Then it expands to much and spews out the weep hole.
Ceramic coated manifolds actually. They radiate a lot less heat so steering temps should be even better than stock. I tried adding thermal insulation to the lines just in case, but it made no difference.
I've sourced a new steering box from Will for a great price.
I run ATF in my S10 pump FWIW. Haven't had any abnormal noise as a result in the couple of years I've had it.
I also added a cooler to my p/s system for a little extra insurance. Added a second factory trans cooler to the front behind the grill and plumbed it between the box and reservoir.
I hope the new steering gear box fixes it for you. I'm just having a tough time picturing it as the problem.
jycsalas
Apr 17, 2009 02:21 AM
