Question before I install the new clutch and transmission...
Old Apr 5, 2016 | 07:46 AM
june82000's Avatar
Default Question before I install the new clutch and transmission...
Just want your opinions here> Should I fool around with changing the rear main seal? It doesn't appear to be leaking and the PO stated that the engine had been rebuilt 30,000 miles ago so I assume they would have replaced it then. There's a Victor Reinz seal installed. I've got clear access to the rear main seal so now would be the time I guess, but I also don't want to risk any future leaks by disturbing it. Is it as simple as removing and installing a new one? Thanks...
Old Apr 8, 2016 | 03:38 PM
DiscoCam's Avatar
Don't change it if it isn't leaking. If you're good with oil changes, then it will never leak.
Just my 2 cents...
Old Apr 8, 2016 | 05:07 PM
Joemamma1954's Avatar
I am with DiscoCam, if it is not leaking, Let it be.
Old Apr 8, 2016 | 10:19 PM
ihscouts's Avatar
That's what the previous owner said about the clutch when the motor was out for rebuild...... let it be. You only get one good opportunity to do something well. Any opportunities after that fact are much less than good or well. Gut instincts should be listened to because the opposite is gut wrenching.
Old Apr 9, 2016 | 07:32 PM
june82000's Avatar
Thanks for the backup on my decision to not touch it, I didn't. Lots of progress today though; finally!
buttocks
Dec 31, 2014 12:53 AM
GentlemanDriver
Apr 24, 2014 06:23 PM
flanker6
May 26, 2013 10:48 AM
xxjtvxx
Aug 13, 2012 12:17 PM
