questions about 98 disco1 maintaince
Old Mar 29, 2012 | 05:40 PM
Gotphill's Avatar
5th Gear
Originally Posted by Chris-bob
Then he shouldn't do it. He needs to focus on what needs repaired/replaced and not bother with induction cleaning unless he has nothing else to do.
yea i am nervous about the clean since its my new truck, but right now its running alright. I forgot to include it seemed it was sitting for awhile before i bought it, has the tow package and was mainly towed behind a rv. there was a lot of rust on the brakes but that wore off as i drove also some dirt at the bottom of the air filter that i cleaned out. and when i went underneath and got it with a grease gun everything was pretty much dry and a very small leak from the rear diff.
Old Mar 29, 2012 | 06:03 PM
Chris-bob's Avatar
I'd just put a bottle of Seafoam in the tank at the next fill-up and not worry about induction cleaning. Spray the MAF with MAF cleaner and the Throttle Body with TB cleaner. Should be good after all that. Oh, and pull the IACV and clean the plunger tip and orifice.
Old Mar 29, 2012 | 08:31 PM
Like these guys said, dont do the induction cleaning, and do not do a engine flush, but a trans flush would not hurt.
Change all the fluids and filters, get the heater fixed and enjoy the truck.
Old Mar 29, 2012 | 08:54 PM
Mountain Goat's Avatar
Awww, it's like you guys don't like making smoke or something.
Old Mar 29, 2012 | 10:41 PM
98D1Chap's Avatar
Pour a can of SeaFoam in the gas tank. Change your own tranny fluid and filter. Heater not working is a serious problem sometimes. (a) previous owner may have bypassed heater core with a "loop" of rubber hose under the hood; because (B) the heater makes water fall sounds from coolant with exhaust gas bubbles in it from bad head gasket; or (c) you are way low on coolant.
My truck has water fall sounds coming from or under the dash. I'm pretty sure I'm not low on coolant. I've read a lot about head gasket jobs around here. How can I know if mine needs replacing? My heater works and the sound has been there as long as I've had the truck which is about two years.
I did have an overhearing problem when I first got the truck. I replaced the fan clutch, water pump, thermostat, and had the raidiator cleanned/flushed. The guage hasn't gone past 9'oclock since.
Old Mar 29, 2012 | 10:44 PM
These are very prone to air bubbles in the cooling system. Could just need to purge the bubbles.
Old Mar 30, 2012 | 04:41 AM
And with a D1 you can put battery corner of truck on sharp elevation, remove radiator bung plug, run and keep filling, until coolant comes out steady, then close the plug. You are trying to force air to the top of the system. Some guys have reversed heater core hoses as well. As for a real test, there is a chemical test you buy for about $50 at the parts store, checks for exhaust gas in coolant, for HG leak.
Old Mar 30, 2012 | 11:37 AM
Chris-bob's Avatar
Smoke is lots of fun...just need to get the other problems worked out before making smoke at the in-laws place...
Old Mar 30, 2012 | 01:20 PM
98D1Chap's Avatar
I'll try this. Thanks!
Oh, I also replaced the cheap plastic plug with a brass one sealed with sylicone.
atancreti
Jul 22, 2011 10:42 AM
grbec22
Defender
Jun 22, 2010 06:59 PM
grbec22
Defender
Jun 19, 2010 09:41 PM
taylorbob1
Mar 21, 2006 12:53 PM
englishboyonice
Aug 5, 2005 03:34 AM
