Quick and Easy Lug Nut Cap Removal
Old Jan 22, 2012 | 05:05 PM
EricTyrrell's Avatar
Default Quick and Easy Lug Nut Cap Removal
Quick and Easy Lug Nut Cap Removal - YouTube
Use a 27mm socket (1-1/16 is too tight) to remove a capped lug nut. Leave the socket on the lug nut. Place a spacer about 30mm in length inside the lug nut. This can be a bolt, steel spacer, 1/4 extension, etc. Thread a M16 x 1.5P bolt into the lug nut by hand. Use an appropriate socket and hand tool or impact driver to continue threading the bolt into the lug nut until the cap pops off. The exposed steel lug nut will now take a 26mm socket (1 inch will not work).
26mm 6-point sockets can be tricky to find. Here's a few sources:
http://buy1.snapon.com/catalog/item....group_ID=20767
http://www.sears.com/shc/s/s_10153_1...=1327274596961
Old Jan 22, 2012 | 05:10 PM
What size socket does the lug nut take with the cap removed?
Old Jan 22, 2012 | 05:18 PM
Edited to include written instructions and exposed steel socket size
Old Jan 22, 2012 | 06:38 PM
wheelgarage's Avatar
This one has to be a sticky....
Old Jan 22, 2012 | 07:08 PM
Already done.
Old Jan 22, 2012 | 09:24 PM
Danny Lee 97 Disco's Avatar
Great Job Eric.
Old Jan 22, 2012 | 10:27 PM
fishEH's Avatar
That's awesome, nice job. Glad I kept all those boogered up nuts.
Old Jan 22, 2012 | 10:34 PM
A+....
Old Jan 23, 2012 | 06:10 AM
DiscoBlanco's Avatar
Great Write up!
(I didn't know the Blue Man Group fixed cars)
Old Jan 23, 2012 | 09:16 AM
fishEH's Avatar
Originally Posted by DiscoBlanco
Great Write up!
Bill, I was just about to email you this thread! Looks like you found a cheap solution to your lug nut woes. BTW, I'm heading to Troy's this Friday if you're interested.
