Quick steering question.
Old Feb 10, 2013 | 12:59 AM
bcbp's Avatar
Default Quick steering question.
How much play should there be when grabbing onto the steering shaft and rotating the shaft by hand? I can't remember if I read somewhere on here that some is normal.
Old Feb 10, 2013 | 07:34 AM
Not enough that you should ask the question. There is an adjustment nut on the steering box that will help. Here is the page from the RAVE shop manual, more info can be found there.
File Type: pdf
Old Feb 10, 2013 | 09:47 AM
Steering play can also come from all the tie rod ends, warn bushing and to some extent, the alignment.
Old Feb 10, 2013 | 10:29 AM
And I forgot about these bolts - # 22 and #11 see attached
File Type: pdf
Old Feb 10, 2013 | 11:55 AM
Why cant anyone just answer a question?
1" of play is normal, 2" is to much.
This is of course with the key on and the engine off wiggling the steering wheel back and forth.
TRIARII
Sep 11, 2014 07:42 PM
jeffery212
Jun 24, 2013 08:27 AM
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
suntattoo80
Feb 14, 2007 09:25 PM
