Radiator Flush Help
Old Nov 1, 2012 | 03:02 AM
CUpgt's Avatar
I'm using a 180 stant super stat out of an older Chevy 350. You just have to drill an 1/8" weep hole in the front of it and it works like a champ
Old Nov 1, 2012 | 06:39 AM
antichrist's Avatar
Originally Posted by mitchb3190
Thank you all for the replies. I also want to replace the thermastat with a 180* one. Can anyone post a link to the one I need to order? And did this seem to help any?
Here you go: https://landroverforums.com/forum/di...27/#post332647
Yes, you want a 180 which is actually the correct one. Here's why: https://landroverforums.com/forum/di...e2/#post208408
Old Nov 1, 2012 | 07:52 AM
Note on weep holes and jiggle pins - those go at the 12:00 position, they allow bubbles to pass and not form a steam pocket behind the stat. And if in doubt about stats, put them to the test before installation. Be sure to ask SWMBO for the proper pan to use. This is important to maintain the balance of life, I don't do kitchen and she don't come under the shade tree except to bring beverages.
Old Nov 2, 2012 | 09:10 PM
mitchb3190's Avatar
6th Gear
Default Thanks for all of the Replies
Now that the radiator is at the shop, besides ordering new hoses do I need to do anything else? Like flushing coolant out of the engine or anything? If so, how would I do this? Thanks for the replies! I am learning as I go, and you people are making it much easier.
Old Nov 3, 2012 | 06:40 PM
With the thermostat housing removed stick your garden hose in the top of the engine, turn it on and flush the block and heads.
Once the water comes out clear you're good to go.
Now stick the garden hose in one of the heater hoses, flush it too until clear.
Then let it sit while you wait for the radiator to be finished.
Old Nov 3, 2012 | 08:42 PM
mitchb3190's Avatar
6th Gear
Thank you Spike
wannabe
Jan 24, 2011 10:42 AM
tsuami1
Jul 4, 2010 05:25 PM
Baylink
Nov 7, 2009 08:49 AM
tunernewb92
Jun 23, 2009 04:44 PM
ToiletDuck
Freelander
Mar 29, 2009 01:46 PM
