Radio "CODE". Disconnected battery.
Old May 10, 2013 | 09:31 PM
RideMTB's Avatar
5th Gear
What if you have called the dealer with the vin and they STILL dont have your code?
Old May 11, 2013 | 08:30 PM
TOM R's Avatar
there is a phone # for rover we were given and we had to fax a copy of the title in my name with a copy of my DL to get the code, they give the code that matches your vin,if your radio has been switched you may be SOL
Old Feb 28, 2014 | 02:38 AM
Teme's Avatar
Default help
missing radio code too, someone help ?
VMLAND4M003447
PART NO. 2CFF-18C838
SERIAL NO. M003447
MODEL. 6500 CD - EUROPE
LAND ROVER PART NO. XQE 000161 PMA
Cheers
-T
Old Feb 28, 2014 | 08:00 AM
TOM R's Avatar
Did you try the local dealer?
Old Feb 28, 2014 | 08:16 AM
Paul Grant's Avatar
If the radio was replaced at any time the dealer will need the serial number off the replacement radio to get the proper code. Before you call the dealer it might be wise to get the serial number off the back of the radio. Give them the VIN and the serial number and they should be able to provide the correct code.
I have a local dealership that I have no affiliation with that has provided dozens of codes for me without ever asking for anything more than the VIN and serial number for the radio. I have never had a request for a faxed copy of a title or registration or any proof of ownership. If you call one dealer and they want proof simply hang up and try another one.
Old Feb 28, 2014 | 08:19 AM
TOM R's Avatar
OK for all those needing the radio case this is what rover required in 2009
Call this #
1-800-637-6837. Ext# 2880
They then asked us to FAX a copy of the car title in my name with a copy of my rivers license reflecting same address
FAX to 201-818-9781
At that time it went atten Joanne and her direct ext# was 2945
So try the dealer but don't hold your breath my brother is a used car dealer and they said no, my buddy owns a shop and buys parts from them enough to know the karts guy answer was no
Probly have to jump through their hoops
Old Feb 28, 2014 | 08:22 AM
TOM R's Avatar
Oh they will give you some procedure for entering the code, my 98 I just turn the key on and punch it in with radio off or on don't recall but no procedure needed
Old Feb 28, 2014 | 08:24 AM
Paul Grant's Avatar
Call this #
FAX to 201-818-9781
That's INSANE and, thankfully, something I have never had to do in the many years I've dealt with Rover parts. I call my local dealer and give them the VIN and radio serial number and they call back within minutes with the proper code. Again, in over a dozen years no one has ever asked me for a title to prove ownership.
Old Feb 28, 2014 | 08:39 AM
Paul Grant's Avatar
I'm just thinking about the absurdity of Land Rover requiring a process like that for a radio that is between 15 and 20 years old. A cassette radio no less.
Old Feb 28, 2014 | 09:18 AM
TOM R's Avatar
I agree, maybe it is just because the local rover dealer does not want to help? I have had no good dealings with them
