Radio won't turn off and other electrical issues.
Old Dec 15, 2010 | 07:02 AM
Spencerfitch's Avatar
Default Radio won't turn off and other electrical issues.
Trucks getting harder to start in the morning.
Going to check voltage tomorrow morning.
Radio stay half lit when truck is off and windows are VERY slow to roll up with engine off.
What's going on?
Old Dec 15, 2010 | 07:33 AM
Rover Chris's Avatar
sounds like you could have a bad light switch, are your city lights staying on?
Old Dec 15, 2010 | 08:24 PM
Long Haul's Avatar
Bad battery or bad ground????
Old Dec 15, 2010 | 08:35 PM
No the lights don't stay on. How can a bad battery or ground cause all this
Old Dec 15, 2010 | 08:37 PM
Long Haul's Avatar
Bad ground can cause all kinds off scewy stuff to happen
Old Dec 16, 2010 | 09:09 AM
okdiscoguy's Avatar
Are you positive your city lights are working? Double check all of your fuses...
I would also have the battery tested and sorted out before you do much more. From there, start checking relays and grounds..
Old Dec 16, 2010 | 09:34 AM
disconnect the negative battery terminal and throw in a cheap test light between the cable and the battery post with the truck off, if it lights up then power is being drawn, the brighter the light the bigger the draw! my next step would be to start replacing fuses with the test light, this will help determine what circuit is drawing the power relatively quickly.
MountainDiva
14
May 23, 2012 03:21 PM
DiscoIIEvan
Nov 13, 2010 06:33 PM
RegT
Jun 3, 2010 09:27 PM
tomfraser
Mar 1, 2009 09:29 PM
crainface
Oct 27, 2008 06:09 PM
