Rattling!!!!!!!!!!!!!!!!!!
Old Feb 4, 2014 | 08:12 PM
coors's Avatar
Broken or loose engine mount?
I just replaced both motor mounts. My drivers side chirps/rattles a little because someone didn't tighten the top nut all the way. "Dad, you sure you tightened your side?! Yup, I think it's good..."
Old Feb 5, 2014 | 06:32 AM
green-lantern's Avatar
I had a rattle like the one you're talking about. I thought the torque converter was going bad. A few weeks later the bearings in the x-fer case got so hot that the truck wouldn't move. I'd suggest at least pulling the fill plug and sticking something in there to see if it's full. Those inspection plates are known to leak.
Old Feb 5, 2014 | 08:44 AM
Charlie_V's Avatar
+1 on that. Transfer case can cause a rattling sound.
Also do you have heat shields on your cats? Presumably you would have caught a rattle when tapping them with a mallet, but the welds for the heat shields can get loose.
One comment you made concerns me. About the u joints. Some movement and assume it is normal. That could be the issue. Mine don't move at all. They did at one time and I removed the front one to find that the needle bearings were almost gone.
Also, I have had to replace cats and the rattling sound they made (both) did not replicate with a mallet.
Old Feb 5, 2014 | 10:25 AM
avo8230's Avatar
will do thanks for your input green lantern
Old Feb 5, 2014 | 10:28 AM
avo8230's Avatar
i will go ahead and replace the u-joints to be on the safe side. not sure if the welds on the heat shield got loose. i will definitely check it. and as far as the "mallet test" is concerned it did not replicate it. but it was worth a try
Old Feb 6, 2014 | 08:58 PM
abran's Avatar
Did you check to see if someone tied a string of cans to the back of your car and wrote in shaving cream "Just Married"?
Sorry, I couldn't resist. Good luck.
twalter87
May 23, 2011 08:40 PM
Phototone
Apr 16, 2008 11:36 AM
wkujesus2
May 13, 2007 07:45 AM
Mikhah
Apr 23, 2007 04:10 PM
scotts_04_Disco
Jun 29, 2005 04:53 PM
