Rear ABS Ring, 98 D1
Old Feb 19, 2012 | 04:28 PM
packkratt's Avatar
Default Rear ABS Ring, 98 D1
Hi,
I'm new to this forum, and this is my 1st post,
I have picked up a 98 Discovery LSE, needs a bit of work for safety, like breaks, some suspension bushings etc.
My Question today is regarding the rear disk ABS ring,
I took off my drivers side disk/hub assembly today to get started on the brakes, and I found that I cannot remove the ABS toothed ring from inside the disk, I managed to get the small nuts off but it wouldn't budge.
Does anyone have any tricks, I would like to keep ABS, but I'm at the point now where I may have to cut up the ring to remove it, I cannot even get to the disk mounting bolts with the ring in there.
I guess my other option would be to take a zip cut disk on my angle grinder and cut away at the disk until i can pry off the ring.
Any wisdom or other tricks would be great
Thanks in advance,
Phil
Old Feb 19, 2012 | 05:13 PM
Its rusted, the 2 have become one.
Heat, use lots of heat and a hammer and chisel behind it.
Old Feb 19, 2012 | 08:40 PM
packkratt's Avatar
Any suggestions how I can get behind it? or do I have to cut up the old rotor?
hipwell
Freelander
Mar 26, 2014 12:44 PM
KyShark
Dec 21, 2011 08:01 PM
mwindth
May 2, 2010 03:47 PM
mattyh007
Sep 17, 2009 10:27 PM
mattyh007
Sep 17, 2009 02:07 PM
