Freelander Talk about the Land Rover Freelander within.
changing abs ring
Old Mar 26, 2014 | 12:44 PM
hipwell's Avatar
4th Gear
Default changing abs ring
hi guys, i changed the front left abs sensor this morning on the freelander as i had the 3 amigos and diagnostics said it was the front left abs sensor.
so i changed that by drilling out the old one as it was stuck.
the 3 amigos are now off which is good
but, now there is a pulsing through the brake pedal when braking which wasnt there before.
Now i recon i have damaged the abs ring when drilling out so so have ordered a new one off ebay for about 6 quid.
So, is it as easy as, wheel off
32mm 3/4" breaker bar to get the hub nut off
2 bolts from strut off.
Shaft out of hub
tap off old abs ring
tap on new abs ring and put it all back together?
ZB-30
Jul 16, 2012 03:41 PM
packkratt
Feb 19, 2012 08:40 PM
Erik
Engine & Internal
16
Mar 25, 2008 07:05 AM
cterrebonne
Engine & Internal
Oct 14, 2006 07:47 PM
sanchez
Aug 3, 2006 10:24 PM
