Rear cargo door will not open
Even though you can see the plunger move up, have you tried using the key? I had to stick the key in the cargo door tumbler and turn as if to unlock it and hold the key in that position. I could then open the door.
If so, you need to replace a wee little spring in the latch assembly.
I suggest getting a handful of the push retainers when you get the spring.
marlymarl
07-28-2005 12:23 AM
