Rear cargo door will not open
I have a 98 disco 1 , the rear cargo door seems stuck the plunger moves up and down with the rest of the doors when unlocking.... how the heck do I get it open... tried inside handle and outside handle
I have had this happen 3 or 4 times. Use lots of WD-40 and wait about 20-30 min, it will open like it never had a problem. Always seems to happen when the back end is full of stuff too. Don't forget to wipe down the door afterwards.
Even though you can see the plunger move up, have you tried using the key? I had to stick the key in the cargo door tumbler and turn as if to unlock it and hold the key in that position. I could then open the door.
If so, you need to replace a wee little spring in the latch assembly.
). I suggest getting a handful of the push retainers when you get the spring.
marlymarl
Jul 28, 2005 12:23 AM
