Rear door speakers not working
Old Dec 8, 2012 | 02:17 PM
DiscoI's Avatar
I just found this harness along the side panel near the alarm unti we talked about.
Any advice?
Old Dec 8, 2012 | 03:02 PM
ihscouts's Avatar
Front speaker amp.
Old Dec 8, 2012 | 03:31 PM
DiscoI's Avatar
THANK YOU!
That was confusing me.
Now it makes sense, they bypassed the front amp.
Now I just have to track down the subwoofer signal cables.
I hope they are in the same area.
Old Dec 8, 2012 | 05:09 PM
DiscoI's Avatar
Sure enough, the sub signal cables were in that harness running through the front amp.
I wired those through with the other patch cables and into RCA cables at the head unit.
Unfortunately the rear speaker cones were torn around the entire circumference of both speakers.
Now I must wait for the rubber to cure for a day before I can test everything.
Attached Thumbnails Rear door speakers not working-101_7585.jpg   Rear door speakers not working-101_7584.jpg   Rear door speakers not working-101_7583.jpg
Old Dec 9, 2012 | 06:35 AM
ihscouts's Avatar
Your welcome and I think you have a penny on the floor......
Old Dec 10, 2012 | 05:06 PM
DiscoI's Avatar
Actually a dime i think
Everything works now thanks guys!
Old May 11, 2016 | 03:05 PM
peejster21's Avatar
5th Gear
Hopefully someone is still around three years later...
DiscoI, how did you determine what those loose wires coming off of the harness under the glovebox went to? I have the same exact problems you're having, but no idea how to go about fixing them.
Old Oct 31, 2019 | 05:33 PM
DiscoNewbe's Avatar
Hi,
I’m having the same problem with my rear subwoofer. Bought new speakers and installed only to find they don’t work. I realized the owner prior who had put in an after market radio never hooked up the subwoofer (no idea why). As a result, I have no idea where to find the subwoofer wires??? You say they’re under the glove box on the passenger side? Is there anything else you can tell me or show me to help me identify what the actual harness looks like?
Thanks for your time!
Adam
Old Oct 31, 2019 | 05:34 PM
DiscoNewbe's Avatar
Hi,
Adam
Old Nov 1, 2019 | 07:38 AM
WaltNYC's Avatar
Any connectors loose inside the rear door? The speakers don't 'work' because the amplifier that was attached to the stock speakers is gone.
The amp in the front of the truck drives only the speakers in the doors, 'A' pillars, and 'D' pillars. The subwoofers have their own amp.
https://landroverforums.com/forum/di...-wiring-43689/
troverman
16
May 31, 2019 06:50 PM
ethomp16
Jul 16, 2011 03:09 AM
DooDer
Mar 25, 2011 04:12 PM
bklahl
Aug 9, 2006 07:36 PM
slamwhit
Jun 18, 2005 02:13 AM
