rear driveline
Old Oct 12, 2012 | 10:13 PM
Shawn Cross's Avatar
Default rear driveline
i have a 1996 SE7 and the rear rubber vibration (u-joint) goes out in about 8000 miles. it doesnt go off road ever. nothing broken. as far as i can see everything else is ok. I hope someone can shed some light. thank you
Old Oct 12, 2012 | 10:45 PM
Its called the flex coupler, also called a roto flex.
If you are using cheap ones they will not last, if you are installing it backwards it will not last, if you have to much suspension lift it will not last.
Jerry B
May 7, 2013 04:10 PM
Disco Red
Feb 4, 2010 11:38 PM
rirover
Jul 4, 2006 03:01 PM
2k2wranglerx
Mar 12, 2006 06:44 PM
LiftedRover96
Feb 7, 2006 10:41 PM
