Red Service Engine Light
Old Mar 15, 2012 | 02:06 PM
felipenaves's Avatar
Smile Red Service Engine Light
Hi all, my service engine light is on in red color for Disco I 1997. I went to Land Rover dealer to reset the light and they told that i need to pull out the relay that is in the kick box by the passenger front seat. They told me that red color means to check gas emissions, is this info right please let me know thanks.
By the way my Disco is running perfect.
Felipe
Old Mar 15, 2012 | 02:26 PM
jafir's Avatar
Yep. remove the relay, and throw it away.
click here to see what it looks like but just ignore that reset. You don't need it.
Old Mar 15, 2012 | 02:34 PM
WaltNYC's Avatar
No need for it. Just a light that is supposed to remind you to spend money at the dealer.
Old Mar 18, 2012 | 08:29 PM
Smile
Thanks
Felipe
Old Mar 19, 2012 | 10:16 AM
DiscoIIBrandon's Avatar
Default Wait a second...
Won't just yanking it and throwing it away leave the light on the dash?
Reset it first, use a paper clip and poke it through the small hole hidden by the Land Rover sticker on the top and make a connection with two small posts inside the relay. Once you've got the light off THEN yank it and throw it away - otherwise I suppose you can pull the bulb - but it would be easier to reset it right before you yank it.
If by yanking it the light turns off then ignore this altogether! But it's annoying having a dash light on...
Old Mar 19, 2012 | 10:48 AM
jafir's Avatar
Yes. The box is what turns the light on. If you remove it, the light goes out, forever.
LeakyDisco
Oct 25, 2012 01:38 AM
tornado_735
Mar 11, 2010 05:55 PM
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
