Removed the K&N Air Filter
Old Oct 7, 2010 | 07:50 PM
  #21
jigray3's Avatar
Originally Posted by antichrist
You don't need the whole head gasket set just to do the valley pan gasket. All you need is about a $30 gasket set.
K&N's claim to fame is better breathing. The only way to do that is to pass more air. The only way to pass more air is larger pores in the filter. Larger pores lets through more dirt.
With all due respect, this is inaccurate. One way to pass more air is to increase the number of "pores" with additional surface area. That is why filters are fluted and why some are more fluted and have more filter media than others. Another way is technology, and K&N is an example of that. Paper elements simply use a different technology than the K&N oiled filter media. K&N can use a less restrictive media because the oil attracts and traps the the smaller contaminants. The paper element uses a physical screening process as you describe. There is more than one way to skin a cat as they say, but in the case of the K&N, it is more work and can potentially contribute to problems if done wrong.
Old Oct 8, 2010 | 08:10 AM
  #22
antichrist's Avatar
You're right, there are other ways to pass more air. Unfortunately the way K&N does it lets more dirt pass. Independent air filter comparisons have shown that.
Old Oct 8, 2010 | 10:44 AM
  #23
jigray3's Avatar
Not defending K&N at all. Tried it, didn't like it for several reasons. Returned to quality dry filter media. Just saying...
Do you happen to have a link to the test you are referring to? I'd be interested in reading it if it's still out there.
Old Oct 8, 2010 | 12:07 PM
  #24
antichrist's Avatar
One was done by Bob the Oil guy.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
I've seen others, but didn't bother to save the URL.
Google is probably your friend.
addeible
Oct 15, 2013 08:06 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Danny Lee 97 Disco
Apr 13, 2010 02:08 PM
muddybuddy
May 14, 2009 02:10 PM
