removing oil pan.. blue gasket sealant...
Old Apr 16, 2012 | 06:55 PM
wheelgarage's Avatar
You know...
Maybe there should be fluorescent colored RTV that glows in the dark. If it leaks, you can easily see it! I think it will sell!...lol
Old Apr 16, 2012 | 07:01 PM
Jake1996D1's Avatar
Originally Posted by wheelgarage
You know...
You know they make tracer dyes for that? Works wonders especially for those hard to find coolant leaks.
Old Apr 16, 2012 | 07:22 PM
ngarover's Avatar
Originally Posted by oilspotLR
I had that problem too, rev it up, and oil light goes off.... I would recommend replacing the oil pump. Its some what of a PIA because of the radiator. I removed my radiator when I did my front cover. Also the RAVE says you have to remove the alternator, a/c compressor, water pump, power steering pump, but I didn't remove any of them. Just the radiator and fan clutch.
Oil pump:
https://landroverforums.com/forum/di...-instal-43603/
Well, might as well do the timing chain at the same time...
Old Apr 16, 2012 | 08:31 PM
Danny Lee 97 Disco's Avatar
If I were planning on pulling the front end apart I would :
Replace fan clutch
replace oil pump
inspect/replace timing chain/gear
pull rad and have it redone
replace thermostat
thoroughly clean all around a/c condensor
use the improved silicone seal instead of old style rope seal
Might as well go in once and hit it all if possible. I may have overlooked something, not really sure.
Old Apr 16, 2012 | 09:00 PM
crank seal
Old Apr 16, 2012 | 09:48 PM
ColoDisco's Avatar
On a 95?
I left the water pump attached, did not evac the A /C, did not remove the alternator, did not remove the power steering pump.
JumPeR04
Nov 23, 2020 07:53 AM
Francopacks
May 31, 2014 12:41 AM
me 2
Jun 13, 2012 06:42 AM
zukilj20
Apr 16, 2012 10:46 AM
JimScream
Jan 6, 2009 02:01 PM
