Replace fuel tank
Check with the local LR dealer, you may end up getting it replaced for free if it was on the recall. My 97DI had the fuel tank replaced on recall prior to my purchase.
Look at the Rover's North webpages for excellent parts breakdown drawings showing each and every part involved.
I would get all new hardware, hangers, bolts, washers, nuts, all the hoses and tubes. Even all new clamps. All the old stuff will be corroded or nasty or cracked or screwed up in some way by the time you get it off. I would not reuse any of it.
Look at the Rovers North Illustrated pages to fully understand each and every part, the part numbers that RN uses and their prices. The great thing is it gives you a starting point that shows all the correct parts in the correct orientation, even if you do not order it all from them.
I also found this post that will be helpful for this project:
https://landroverforums.com/forum/di...nt-hose-41987/
aguison
Nov 18, 2012 05:15 PM
me 2
Jul 5, 2012 07:40 AM
