Replacing Camshaft
Old Apr 9, 2012 | 08:52 AM
slanginsanjuan's Avatar
so, remind me, what was the failure...is this "the tick"?
Old Apr 9, 2012 | 08:57 AM
ColoDisco's Avatar
Yes. Engine tick from my other post. There is a video in that post so you can hear what I hear.
Old Apr 9, 2012 | 09:03 AM
right. i was following that. maybe dumb question but does this anything to do with the slipped/pin liners problem/solution?
Old Apr 9, 2012 | 10:46 AM
ColoDisco's Avatar
Which pin and liner?
Old Apr 10, 2012 | 08:58 AM
Jake1996D1's Avatar
I think he is asking if you have pinned liners? Or maybe a failing liner? if it's happening at start up then likely not. If it's happening when it's warm - maybe. But on a 3.9 my "ticking noise" bet is cam and lifters.
Old Apr 10, 2012 | 08:59 AM
Jake1996D1's Avatar
I already switched to 15w-40 rotella with a the recommended larger oil filter. I will stick with the recommended break in oil for the cam (valvoline VR-1 taken from discoweb) then go back to the rotella.
Smart man
Old Apr 10, 2012 | 09:37 AM
ColoDisco's Avatar
Using a stethoscope I hear it loudest by the lifters. Pretty sure my piston liners are fine.
Old Apr 10, 2012 | 11:51 AM
Danny Lee 97 Disco's Avatar
Other than the tick, how does it run?
Old Apr 10, 2012 | 09:12 PM
ColoDisco's Avatar
Feels rough. Almost like a misfire but I am not getting any misfire codes.
Any advice on loosening the crank, cam bolts without the special tool?
Old Apr 11, 2012 | 06:40 AM
there's a hunter s thompson-ish write up in the D2 section about how the guy pinned his liners and stopped his ticking. a few guys say that's common for the D2.
No diff for the 4.0 tho right. same bet?
