Retrofit D2/P38 Cruise Control ECU
Old Dec 28, 2014 | 04:46 PM
  #31
Figaredo's Avatar
Thank you FishEH for the detailed pictures.
Paul Grant: Do you still have the ECU's? I would like to buy one from you!
Old Dec 29, 2014 | 10:33 AM
  #32
Paul Grant's Avatar
I have a couple left. They're $20 a piece with free shipping. They come with the pigtail to help with the wiring. If you'd like one, my PayPal is paulgrant@mac.com. I can get one out right away.
Cheers,
Paul
Old Aug 13, 2016 | 07:02 PM
  #33
spurcap's Avatar
I am going to do a write-up here if it works but I am doing this retrofit without a pigtail by modifying the connector on the AMR 5700 and removing the connector socket from the old board.
But one thing I was hoping someone can confirm:
- On the AMR 5700 what is the pin ordering?
Looking at the 18 pin connector with the board facing upright, the top pins are mounted into the board furthest away from the socket end of the board and the bottom 9 pins are mounted into the board closest to the end of the board. If the same as the old unit, pin 1 would be the bottom left pin and the pin out would be as follows looking at the connector with the board facing up:
10 11 12 13 14 15 16
1 2 3 4 5 6 7 8 9
But no way to assume this is the case....
If some one has the pigtail they could tell me the color of the wires going to a few of the 18 pins and I should be able to figure it out.
Again my references are with circuit board components facing up, not sure how it positions in the black housing.
Thanks!
Old Aug 13, 2016 | 07:14 PM
  #34
spurcap's Avatar
I could have said that easier. I rerealizehe pin out is shown on the black housing but don't know if the board goes in the housing face up or down as I have it ripped apart.
Old Oct 23, 2025 | 03:39 PM
  #35
Membrukats's Avatar
Default Thanks!
Hi all,
Just wanted to shared that I managed to retrofit the new Cruise Control ECU with this Thread.
and I created the new connectir with the pigtale and previous case so I did not have to cut my wiring loom.
Amazing! Thanks a lot. I believe someone created a PDF with all the process if someone is looking for it, but this post has all the info.
Thanks!!
EricTyrrell
Feb 18, 2013 11:30 AM
MrMayorDA
Feb 14, 2012 09:39 AM
Weskechi
Mar 29, 2010 07:16 PM
Camdisco24
Aug 11, 2009 06:03 PM
BYURover
Jul 18, 2007 09:00 AM
