Rewiring '95 disco rear subs, help!
Old Aug 18, 2014 | 12:37 AM
christiansmith6's Avatar
Default Rewiring '95 disco rear subs, help!
So whatever jack wagon owned my disco before me completely messed up all the stereo wiring. They bi-passed the amp and just wired everything directly to the head unit. I know that this is a common fix as the factory amps tend to be garbage, but the subwoofers in the back no longer work. I'm also not entirely sure if either the amp beneath the passenger seat or the one behind the subwoofer works.
So I have a few questions.
-Does anyone know which color wire is what for the main amp wiring harness?
-Does anyone know of a way to test to see if the amp is still working, for both the main and the sub amp?
-Assuming the amps still work, is it better to just rewire the whole thing or is it better to try and salvage what is left?
-Assuming the amps do not work can anyone recommend a head unit powerful enough to run the subs with full quality or a recommendation for an amp that goes well with the disco and the factory sound system?
Any help is much appreciated, thanks in advance!
TripleThreat
Feb 10, 2014 08:39 PM
98roverguy
May 14, 2009 06:41 PM
thesearch35
Feb 20, 2009 09:40 PM
guitarz32388
Jun 22, 2007 10:04 AM
brunettc
Audio/Visual Electronics
Aug 8, 2005 07:31 AM
