rod big end specs - 1997 4.0 DI
Old Jun 26, 2010 | 10:45 PM
greg409's Avatar
Default rod big end specs - 1997 4.0 DI
Has anyone noticed the rave shows 2 different sizes for rod journals on the crank?
workshop manual - 4.0 specs - crankpin journal 2.1850 - 2.1855"
overhaul manual - 4.0 rod big end - 2.20 - 2.22"
I've always known the "crankpin" to be the rod big end.
I'm going to throw a set of bearings in as preventative maint. soon and that's a big diff.
luck,greg
Old Jun 27, 2010 | 08:09 AM
kenk's Avatar
Yea, something is definitly up with that. I would trust that first number, but the second? .020 variance? That tolerance is way outa the ballpark for a bearing dia.
I have learned to always double check what the rave says. I was looking up my fuel pump relay recently. Supposudly in the pass. footwell area. Nope. It's under the hood. And it's like a $100 assembly, not a $7 relay.
Old Jun 27, 2010 | 02:54 PM
AK Rover's Avatar
Since they come from 2 different sources I would suspect the overhaul manual is taking about .020" oversize bearings as opposed to the standard bearing size in the workshop manual.
Old Jun 27, 2010 | 08:13 PM
greg409's Avatar
It would have been too much for them to state that.
Both references list the same metric size, tho"
I also don't like that they state do not re-install old bearings, didn't they ever use plasti-gauge?
luck,greg
TRIARII
Feb 21, 2013 10:33 PM
Cottrell
Sep 20, 2012 01:24 PM
Clunker
May 9, 2011 08:16 PM
Christian_X
Oct 27, 2008 05:54 PM
StephenK1706
Jan 17, 2005 05:45 PM
