rotoflex direction
Old May 16, 2019 | 08:26 AM
gc3's Avatar
gc3
Default rotoflex direction
Hey guys,
I've noticed everything the previous owner mentioned he replaced or fixed has been full of issues.
the rotoflex on the bottom of the rear d-shaft. He mentioned he replaced it, it looks pretty new, but I don't see any arrows.
Which direction is it supposed to be mounted? the fat lobes are supposed to be in compression or tension under forward driving?
Old May 16, 2019 | 09:04 AM
OverRover's Avatar
No arrows normally means that is a cheap-o rotoflex and not a quality GKN.
But forget the arrows, so either way just install the bolts/nuts correctly like in the pic below.
Old May 16, 2019 | 09:12 AM
gc3's Avatar
gc3
thanks, aha. so fat in compression.
As expected, mine is backwards. I will be flipping it around.
Old May 19, 2019 | 12:50 AM
ihscouts's Avatar
So fat in compression? Dude, what you do in your spare time is your business, you don't have to share it with the world wide web.
Old May 19, 2019 | 01:07 AM
ihscouts's Avatar
I wouldn't pay for the arrows cuz it's only common sense that the shoulder goes through the bushed rubbah with the lock washer against the steel flange. That's an uh duh sort of simple midget minded thing. The whole rotisserie-flex is a backassward thing to begin with, use a common u-joint cuz it's not gonna negate the driveline "clunk" no matter what you throw at the pinion flange.
Old May 20, 2019 | 06:10 AM
gc3's Avatar
gc3
turns out if you look for the arrows they do exist.
And also the PO definitely had it in wrong as expected. (and bolts in, all 6 facing the same direction)
thanks for the help!
Ben Matheson
Sep 21, 2018 09:58 PM
elboy0712
Dec 10, 2017 05:40 PM
KingKoopa
Aug 10, 2017 10:21 PM
SDinDS
Jun 7, 2011 12:33 AM
03discoman
Dec 28, 2009 02:43 PM
