Rough Idle (need help)
Old Aug 23, 2010 | 11:30 PM
rasaquan's Avatar
6th Gear
Default Rough Idle (need help)
Have a 1996 disco has new plugs and wires and still idles rough the check engine light comes on p1307 misfiring on no 7. Did a compression check on all cylinders 175- 180 on all cylinders. Its running rich the no 7 plug is a bit damp form I think fuel.
Is it possible that the push rods are bent? On cylinder 7 I live in Toronto and it's due for emission test I know it would not pass. I need help
Old Aug 24, 2010 | 12:47 PM
Bajapower's Avatar
If your plug is damp from fuel, id lean towards an ignition issue before i jumped into valvetrain. If you've got compression and fuel, your lacking spark.
Old Aug 24, 2010 | 01:31 PM
discomedic4's Avatar
You can check the spark on each cylinder by removing the spark plug, plugging it back in while it is out of the cylinder, firing up the truck and just look for the spark.
Old Aug 24, 2010 | 02:10 PM
ColoDisco's Avatar
Clogged injector? Bad spray pattern on #7 nozzle?
Old Aug 24, 2010 | 08:29 PM
rasaquan's Avatar
6th Gear
They have 4 coil packs (2&3) (4&7) (8&5) (6&1) if one of the packs fail would the engine still run?
dillhole
Feb 20, 2020 02:30 PM
DiscoIIBrandon
Jul 10, 2018 07:47 PM
KGN96discoSE7
Sep 23, 2017 07:23 AM
ridesnow85
Jun 12, 2014 02:42 PM
j.dstasio
Mar 14, 2013 12:28 PM
