"rough" idle & start but smooths out?
#22
This stuff works GREAT!!!
I used it on my wifes car, her radiator was leaking at the seam on the passenger side, shook it for 1 min, poured it into the cold radiator, and drove for 30 min, parked the car and let it sit all night, has not leaked for over a month now.
Amazon.com: K-Seal ST5501 Multi Purpose One Step Permanent Coolant Leak Repair: Automotive
I would try it, the only way it will clog the radiator is if you use to much, only use one bottle, if that does not work then you need to bite the bullet and fix it right, it should be fixed right in the first place, but this would get you buy.
#23
