Rough Idle, will not rev above 1k, undrivable
Old Dec 1, 2018 | 09:18 AM
_ExpeditionMan's Avatar
Default Rough Idle, will not rev above 1k, undrivable
All,
Had my first Disco breakdown that stranded me yesterday... I had just finished cleaning out the interior after a car wash and was trying to drive away when the Rover decided it didn't want to rev past 1000 RPM. At first, it had power under this threshold and I was able to limp it using all 5 gears (R380) to a nearby parking lot. However, the engine got worse and worse, beginning to misfire heavily, to the point where it was undrivable, even in low range. Now if I attempt to rev past 700 RPM it breaks up and sounds awful (misfires, popping from exhaust) and runs horribly at idle. I had zero check engine lights during this time and finally ended up getting a P1314 error code. All this tells me is that misfires on the passenger side bank are causing catalytic converter damage. Has anyone seen these symptoms before? I attempted to troubleshoot on my own, including checking all 5 vacuum hoses for leaks (none), using a fuel pressure tester on the rail (above 30 psi at idle and rises with revs), and checking connections to all wires and spark plugs.
Any thoughts?
Old Dec 1, 2018 | 04:31 PM
ihscouts's Avatar
Check connectors for water intrusion, one of most common problems. MAF, coils, injectors, CKpS, TPS and so on....... At the time your Disco was made LR didn't exactly have waterproof electrical connectors quite right.
Old Dec 1, 2018 | 06:19 PM
stillruns's Avatar
What year is it?
Did LR ever waterproof the D1 electrical connectors correctly?
Old Dec 1, 2018 | 07:07 PM
ihscouts's Avatar
96. Uh, no I was being sarcastic. On the 2002.5 L322 they did a better job of it.
Old Dec 4, 2018 | 01:13 PM
Thanks guys. Could not find any evidence of water causing problems with connections, however I too suspect that water is responsible. The truck got towed to the shop so I am hoping to find out a little more this week. I will report back if I find the cause.
Reddisco1
Oct 14, 2015 03:44 PM
wrongway1
Feb 19, 2014 06:35 PM
Street Wolf
Sep 6, 2011 04:15 AM
94svt50
Mar 6, 2011 09:10 AM
IDAHODISCO
Jul 10, 2009 09:34 PM
