routing guage lines
Old Jul 16, 2014 | 06:50 PM
HammerFit's Avatar
Default routing guage lines
https://onedrive.live.com/redir?resi...CDEA3597%21107
Now that I got this opened up, I need to route the temp, oil and voltage lines for the guages. I either need to replace my digital clock that light bulb is out or replace the bulb. How hard is it find that tiny bulb? Same wires for the digital work for the analog? That would be a major deciding factor.
I've had a pioneer head unit I wanted to install and now that dash is open, need to get that done. I need a cage to fit this unit and the small trim that goes at the bottom front of the opening. Need to match up the plugs from the new unit to the Rover wiring, that one shouldn't be too difficult, seen that posted somewhere on here.
And I might as well add 3 switches where the coin tray was. I need at least one for the front lights. I do want to install a light bar on the roof rack at some point too.
Here's the big question. Where is the best place to get through the firewall from the center dash?
Luckly I have a spare center dash unit on hand. I took the old one out the fast way!
Old Jul 16, 2014 | 07:10 PM
Shiftonthefly1's Avatar
Some one on here replaced the bulb w an led I think
Old Jul 16, 2014 | 07:29 PM
fishEH's Avatar
Radio Shack has the bulbs I think.
Run the wires/lines through the firewall grommet on the drivers side. You'd be surprised how much will fit through there.
Old Jul 16, 2014 | 09:05 PM
Gimebakmybulits's Avatar
Links for the bulb and clock removal, just did mine 5 min ago. I used the green LED and it looks great.
B8 LED Bulb - High Power Instrument Panel LED | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs | Super Bright LEDs
Land Rover Discovery Clock Replacement - Product Instructions
Old Jul 17, 2014 | 07:26 AM
HammerFit's Avatar
Originally Posted by Gimebakmybulits
Thanks for the tip! Holding all 4 tabs down at same time requires monkey skills. Just sayin!
Old Jul 17, 2014 | 03:22 PM
Glad it wasn't just me thinking that, I damn near just ripped it out. I was so frustrated at one point then pop, out it came.
Old Jul 17, 2014 | 06:19 PM
HammerFit's Avatar
The link you provided is that the same exact bulb you used? Hope so just ordered. Thanx!
Old Jul 17, 2014 | 07:32 PM
Yes, I got the green bulb like others on the forum suggested and it rocks.
Charlie_V
Aug 23, 2015 05:27 PM
TRIARII
Feb 26, 2015 11:13 AM
Dino76
Aug 19, 2007 10:21 PM
OlDood
Jul 13, 2007 12:24 PM
danepeople
Oct 17, 2006 10:10 AM
